Thread: spa help
    Feb 2018
    Kansas City
    2
    spa help
    We designed a custom 9x6 gunite spa. It's completed and I have some questions to others that have done that.
    1 - how deep is the well for your feet? my husband is 6 foot and his feet dangle.
    2 - how deep should the seating bench be. The water level is hitting my husband about 2 inches above his belly button.
    3 - where are your jets? Ours hit our butt crack (sorry for the visual).
    4 - how's your jet action? Our water barely swirls.
    wjr75's Avatar
    Jun 2013
    IL
    878
    Re: spa help
    Something doesn't sound right with this design. We have a large spa and we have two bench heights one on one side of our octagon being about 3" higher than the other side for shorter peeps. Our feet touch the bottom of the spa and our shoulders are just about at water level depending on what side you sit. Our jets hit you in the middle of the back if you sit in front of one. Maybe your seat height need to be adjusted??
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Feb 2018
    Kansas City
    2
    Re: spa help
    Quote Originally Posted by wjr75 View Post
    Well, after complaining again, our contractor is cutting the gunite out and redoing the bench lower. He didn't want it as low as we do and he cannot figure out exactly what happened for it to be like this....somewhere along the way the calculations were off. We are just happy he is fixing it.....
