Thread: Sand filter top won't come off and leaks
    Feb 2018
    Jacksonville
    1
    Bought my house with a pool last year and the sand filter and multiport valve leaked. I've recently replaced the pump and the multiport valve but the sand filter still leaks at the top and at the inlet and outlet ports. It is a Triton TR60 and appears very old. I cannot remove the top for the life of me. I feel like the plastic lever is going to snap before the top even budges a little. Is there a trick to opening the top? If I can get it open is there a chance it will be an easy fix to stop it from leaking? Or is there a sealant or glue I can try to put around the top as a stop gap measure until I buy a new filter? I've priced a new top and valves and it would seem smarter to just buy a whole new filter.
    Any thoughts?
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: Sand filter top won't come off and leaks
    Welcome to the forum!!
    My only comment is that the filter is a pressure vessel. If the leaks are in any way due to a compromised shell discontinue using the filter now and get a new one.
    To open it, be sure the pressure is bled off. Then try tapping the shell above the joint that separates the two halves. That may loosen it.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
