Results 1 to 9 of 9
Thread: New dark plaster having white spots
    Apr 2015
    Saint Augustine Fl
    43
    I had my pool refinished with a black finish over thanksgiving and slowly the pool finish is having white streaks
    I put the anti scale agent every 3 weeks and I followed the instructions from the pool folks who did the install.
    However they are advising me since the pool is new that PH 7.6 is to high and to keep it at 7.2
    I check my water 2 times a week and it’s around 7.5-7.6 and everything else is normal
    Here are the feb numbers
    Where there is an x I didn’t perform the test
    2/4
    6.5 chlorine
    325 calcium
    90 Ta
    45 cya
    7.8 ph
    2/7
    5.5
    X
    90
    X
    7.5
    2/11
    6
    275
    80
    X
    7.6
    2/14
    4.5
    X
    70
    X
    7.6
    Would the PH really have an impact on scaling? And if so is my ph to high?89672146-DDF2-4AFF-B728-FFCB2D4E0E76.jpeg
    Fresh Warer pool15k gallons
    Pentair Clean and Clear RP filter
    Pentair 320 chlorine filter
    1-1.5 Hp pump//TF-100 test kit
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    Re: New dark plaster having white spots
    pH has a significant impact on scaling - see Pool School - Calcium Scaling
    However, a number of posts on this forum have shown that dark plaster has extensive 'mottling' and is subject to noticeable imperfections.
    From your tests I do not see an issue with your CSI. Do you track that parameter? It is calculated in PoolMath and in the App.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Apr 2015
    Saint Augustine Fl
    43
    Quote Originally Posted by mknauss View Post
    Take care.
    I am inputting the test values from the pool kit from troublefreepool store and entering them in the poolmath website
    I do my tests on Wednesday and Saturday/Sunday
    I scrub the pool floor and walls twice a week
    I vacuum the pool on the weekend and clean he filter on the weekend
    May 2014
    Laughlin, NV
    11,793
    With new plaster you should be testing pH every day. That way your pH does not swing high/low/high.
    How do you chlorinate?
    Marty
    Apr 2015
    Saint Augustine Fl
    43
    I tested the pool every day for the first month
    But looking at my data is it swinging wildly?
    I am using liquid chlorine to reach the level recommended by the poolmath and I have a puck and it’s set at 1.5
    I can start testing the ph daily and see how much it’s changing
    Jan 2012
    'burbs of Augusta, Georgia
    8,872
    Are you using muriatic acid to lower your pH when it rises? Don't use dry acid-not recommended as good for plaster or SWCGs.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Apr 2015
    Saint Augustine Fl
    43
    Quote Originally Posted by YippeeSkippy View Post
    Maddie
    Iím using muriatic acid
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,760
    My pool is fairly dark and when I purchased it, it had a good number of white spots (or small white nodules) all over the bottom and sides. There were also some white streaks similar to what I see in your picture.
    On a whim, I picked up a potato shaped pumice looking rock from the flower bed and tried scraping off one of the spots. It worked great, and didn't leave any marks on the pool itself. So my OCD kicked in and I spent the next several evenings scraping every spot and streak off that I could reach (I'm going to need some scuba gear to finish the job). But I'd guess that 90% of all the white came off and it looks much better now.
    From what I've read, these spots are due to calcium from the surrounding soil leaching back through imperfections into the pool. Your problem may not be the same, but I thought I'd throw this out there as something to try.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Apr 2015
    Saint Augustine Fl
    43
    The company that plastered my pool said the stucco dealer looked at the photos and said the following
    “calcium Scale Plated Out, hit it with the Jacks Number 2 treatment, but wait until the water warms up or it won't work".
    I am dumbfounded tho as the CH was at or below 325. And ph within normal levels
    I am wary of draining and acid wash since I don’t know how to prevent it again.
    I was thinking of lowering ph to 6.8
    Then use steel brush alongside pulmice stone to remove scaling
    Is that idea sound?
