Thread: 2 or 4 wheel Poolvergnuegen "The Pool Cleaner"
    Hey guys,
    From a size standpoint, the two-wheel version is more than adequate for my pool. However the shallow to deep end transition is rather abrupt, going from 3 feet to 5 feet over a span of only about 8 feet in length. I have heard the 4-wheel version handles inclines better, but tends not to be as maneuverable as the 2-wheel version. Also it's more expensive and has more parts that could break. Any suggestions on which one to go with? If I can get away with the 2-wheel, I'd prefer that, but not if it means it'll never climb out of the deep end! Thanks!
    Jan 2012
    Hanford, CA
    38
    Re: 2 or 4 wheel Poolvergnuegen "The Pool Cleaner"
    I have a similar pool incline and my 2 wheel Poolvergnuegen handles it just fine.
    7,000 Gallon In-ground Plaster Pool, Spa, & Waterfall
    Jandy Stealth Pump, Jandy DEV60 Filter, Jandy LXi400N Heater, 8 Gallon Liquidator, The Pool Cleaner
    Taylor K-2006C
