Results 1 to 2 of 2
Thread: Step by step for salt pool refill
  1. Back To Top    #1
    Join Date
    Feb 2018
    Location
    raleigh, nc
    Posts
    1
    Hey guys, First post...
    I am having to drain and refill my above ground pool for various reasons (water is full of iron, want to relevel sand bottom, want to paint the rails)...anyway, I'm looking for very detailed step by step instructions for refilling and basically building the water from scratch. Things like...do I add the salt after pH and alkalinity are right? Thanks!!
  2. Back To Top    #2
    needsajet's Avatar
    Join Date
    Jan 2016
    Location
    Sydney, NSW, Australia
    Posts
    4,513
    Re: Step by step for salt pool refill
    Welcome to TFP! Good to have you here
    Day 1
    For me, it's pH first
    Then a small amount of chlorine to stop anything from starting to grow, say 2 ppm
    Then CYA to protect the chlorine, 30-50 ppm
    Day 2
    Assume CYA level is at your target, and add the right amount of chlorine per FC/CYA Chart
    Adjust pH if need be
    Day 3
    Check TA & CH, but don't do anything about either
    Adjust pH
    Top up chlorine
    Add salt
    Report all your numbers here to let us know. If anything's untoward, we'll let you know
    Day 4
    Adjust pH
    Top up chlorine
    Turn salt cell on at your best guess level
    Then test pH and FC every day for a few days to see if the SWG is keeping up; adjust it as needed
    Within the first week or so, do an overnight chlorine loss test to rule out any algae carrying over from before the fill Overnight Chlorine Loss Test
    Then raise your CYA to 70-80 ppm (correct level for a salt water pool)
    When you can, set up a signature - see Pool School - Getting Started - which will help you get the best possible advice.
    Also, read these (they're all short) and it will all start to come together.
    TFPC for Beginners
    ABCs of Pool Water Chemistry
    Pool School - PoolMath
    PoolMath
    Pool School - Water Balance for SWGs
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
Posting Permissions
  • You may not post replies
  • You may not edit your posts
