Adding UV Without Spending $1000
Why did you stop using it?
My very unscientific testing showed it was providing no benefit. It looked like I was using more chlorine with it plugged in. I have an autocover so my pool only gets sunlight only when we are using it. Once it was unplugged my FC drop seemed less between uses, unfortunately I did not log my results in the pool math app so I don't have the numbers to back it up.
Look at SpectaLight UV. They make an in-line single bulb system.
Very likely. UV-C does interact with chlorine and will neutralize it. If there are no organics around to oxidize, the UV light will destroy FC.
