So with the help of this forum I have been getting my hot tub water levels right. After purging with Ahh..some I refilled and started over. Mine is a bromine tub, so I added the recommended level of sodium bromide to establish my bromine bank. I also added a cup of liquid bleach right away. After about 4 days of adjustments, my numbers today were-
Ph - 8.0. Added dry acid to bring down to 7.2 or so
TA -60. Was low so have been adding Alkalinity Up
Bromine 8.0.
My Bromine level has been hovering between 7.5 and 10. I have not added any bleach since the initial cup four days ago. We have used the tub twice, with a total of about 1.5 person hours of use. I keep the cover on at all times when not in use. The capacity of the tub is 250 gallons.
My “newbie” question is how does the Bromine level go down? I
Understand my target should be around 4-6.
If I don’t use it will the Br level go down naturally with time?
I assume that using the tub will bring down the Br level? That’s why I would normally add a small amount of bleach after every use?
Thanks for the help. Hopefully I’ve made myself clear [emoji6]
Bromine 8.0.
