Hi all,
I bought a used Zodiac MX8 in great condition a few months back. I did some preventative maintenance before dropping it in the pool by replacing the motor, drive shafts, and rubber wheels. All else seemed to function well. It seemed to work fine for a few months but now Im having a weird issue. My shallow end steps are like half moons. Three descending to the bottom in larger diameters. They are quite smooth and rounded on the edges. The cleaner goes up to the bottom step, attempts to climb it, then gets sucked down and pressed against the curved surface. This stops the bottom turbines from spinning essentially stopping the wheels from turning. Also, if it dosent climb the step, it just butts up against it and spins the wheels. It tries to reverse itself but it wont go straight backward. It just tries to spin one wheel at a time which keeps pressing it forward up to the step. Does it sound like the drive gears need replacing or is it just the steps present an insurmountable problem? Thanks
