Had this thing for about four years. Recently, it keeps getting stuck on stairs, odd corners, or the hose coupling in the pool wall. I am wasting electricity having the cleaner pump running for two hours with the cleaner stuck in one place (unless I manually free it). And, of course, the pool is not getting cleaned properly.
Inspecting the unit, I can see no problems. Wheels spin at normal rate, rubber treads are fine, suction is still good. When I free the cleaner from being stuck, it shoots off and works as it should....until it eventually loops around and comes back to a stair, corner or the wall coupling and gets stuck again.
My best guess is that the backup valve on the hose is not working properly to back the cleaner out of these trouble spots, but I am not sure how to confirm before I drop $50 on a new valve. I have opened the valve housing, and the gearbox appears to be spinning freely as it should. I am not sure if the gearbox is becoming dislodged inside the housing once it is in the pool and tumbles around a bit.
I would welcome any other suggestions on troubleshooting this problem, or verifying that the backup valve is indeed the culprit.
Thanks much!
Thanks much!
