I've finally decided to replace my current pool pump with a variable speed pump, the Hayward SP2302VSP Max-Flo VS. I need to upgrade the dedicated circuit from 115V, what the prior pump ran on, to 230V. I'm trying to buy the parts for the electrician so that it will take as little time to put in as possible and, hopefully, save some money. My understanding is that I can run the 230V on the existing 12/2 (with ground) line. As for the circuit breaker, I'm thinking I need to go from the current 20 amp single pole breaker to a double pole 30 amp breaker. Does that sound correct? The pump is only specced for 6.9 amps though. Also, does the breaker need to be GFCI? Thanks in advance for any help!
Hayward SP2302VSP Max-Flo VS Variable-Speed Pool Pump, 230 Volt, Single Phase
