I will try to make this long story short. I record our water meter the same day the local MUD reads it and it seems like I am using more water than I should be for this time of year in the Houston area. I don't think I have a pool leak but what would be the best way to tell if I do? I turned off the auto-fill at the water spigot to see how quickly water is being lost, regardless of HOW. There should be minimal loss from evaporation since the high temps are 70 (or less) right now. I don't detect any wet spots where there might be a leak in the pool plumbing.
What would you expect loss from evaporation to be around this time of year for an 18,000 gallon pool that has a surface area of ~30' x 15'?
I have our sprinkler system off, so water usage is limited to just household use, which should be fairly low for a family of 4 (which includes 2 kids under 2 years).
Any general ideas to track why our water usage might be higher than expected?
