I have an older AquaSwitch Panel. The label on the box is marked Model: 7300/7488/7495/7496. Its old but it works great. Before the winter starts I wanted to install an anti freeze kit that would turn the pump and heater on when the outside reached freezing temperatures. I looked at the installation guide and it said under "Installing Optional Equipment", "Mount the Freeze Sensor in the Low Voltage raceway, as per instructions included in Freeze Sensor Kit, Part No. 7026. I went online and ordered as Adjustable Freeze Protection Kit - 7026. This sensor has a knob to adjust the temp for turning on the switch. I removed the bezel panel from the box, installed and connected to the correct wiring spaces indicated.Went to re-install the panel bezel but it will not close because the knob protrudes to far out. Do I have the right part (Part # 7026)? After I figured out it would not close, I un-installed it and never powered it on since I did not want to blow the board if I had the wrong part.
If this is the right part? It is possible to drill a whole in the front bezel to accommodate the switch, but I don't want to do this if its the wrong part and in the end will not work, or worse end up frying my board which I do not want to replace. Has anyone had experience with this unit and freeze sensor? I am adding pictures that illustrate.
