Hey everyone.
I've read and used your advice countless times as a diehard DIYer, but I am in over my head this weekend.
My original FloPro 2 speed pump was cracked and rusting out, so we decided to try installing a variable speed Jandy ePump 2.0. We have the Jandy Aqualink RS Control panel, with the PDA, and iAqualink version R connected. We only really use the PDA on the patio. Also, we have the aquapure 1400, LRZ Heater, and a 1 HP Flo pro pump for the spa.
Removed old pump and plumbed for new pump. So far so good. Started reading electrical connection section. Not good. First I had 4 wires, 2 red, 1 green, and 1 black, and there are 3 connections on the new pump, L1, L2, and Ground. I read a little more in the forums and saw that my previous pump was a 2 speed and then saw the 2 speed relay added to the box. So I bypassed the relay and used only the red wire from the 4th terminal on the Pump relay. I crossed my fingers and just connected the red and black to the pump, and the green ground wire. Also, I placed the large green ground that was attached to the outside of my old pump to the large ground terminal on the JEP.
Next I attached the RS485 cable to the Pump and ran it to the aqualink control panel. Surprise! I dont have any open RS485 Connectors, and my Multiplexer board is full as well. Back to the forums. I see several posts that states you can attach more than one cables to the RS485 connector. I add it to a connector on the multiplexer board.
I turn on the breakers and press Pool pump on my PDA.. No pump, but my spa pool light turned on. I checked my connections and obviously I am not hooking this up correctly.
Ive attached pictures on the aqualink RS control panel, the 2 speed relay I bypassed, the Multlplexer board I tied the pump controls to and the Pump.
Help.
Help.
