Hey all,
I have an above ground pool w/ a small hole in the vinyl liner at the bottom of the pool. I'd say its about 1 - 1.5cm. I bought some boxer glue and used the vinyl that came with it to patch it up.
Water leakage has SLOWED, but not eliminated. I had planned to close the pool this coming week... with this new issue, I'm not sure how best to proceed. I'm in the NY area, so weather has cooled a bit, but no freezing. I don't know how old the liner is... but the liner does have other areas of wrinkle. No other holes/leaks are noted.
Hoping for some input on my issue---
-Should I repatch, but with actual pool liner?
-Should I bite the bullet and replace the whole liner (not sure how additional wrinkles would factor into this)? Is this an overreaction?
First time pool owner, any advice would be greatly appreciated!
Thanks!
Thanks!
