This is my first year with a pool and luckily I saw this website and joined the club. Anyway I have been fighting this algae. Earlier on this summer I let the fc get down to 2 and it started to algae. I slammed it and cleaned it up and back to normal. About a month ago I think the pool got an overload of algae or something from putting the cover on that was off for a couple weeks as it was warm out. Plus I wasn't running the pump enough. So I slammed. The strange thing is i had been using about a half gallon of 10% bleach every other day before the slam and it always had a bit of CC and the pool was perfect. Now it is closer to a gal a week if that. I thought this is great I must had got a good kill and this was the new norm. Fc barely dropped and no CC until recently. Well maybe not.. it was pretty good but not perfect then we got a heavy rain that washed the solar cover pretty good and this showed up. I will need to slam again of course but is it strange that it is burning very little chlorine and the filter isn't building much pressure from algae? The FC has been kept around 7 and never went below 4. Is this regular algae or a mustard that needs a higher dose. All the black blotches on the bottom are leaves not algae.
Currently
FC 7
CC less than .5 (barley turns pink)
ph 7.3
TA 90
ch 125
cya 40
Currently
FC 7
ph 7.3
TA 90
ch 125
cya 40
