Hi,
Happy to make my first real post and request for advice. Our new Quartzscape Plaster was completed June 8, a few months ago. I believe I've got everything balanced to the TFP SWG ranges. The water looks good (note minor algae comment below.)
I test chlorine and pH every day, TA & CYA about every 10 days, CH about twice/month as everything gets settled. I'll post my latest readings below. My main question is about acid demand. I am going through one gallon of 31.45% MA every 5 days, adding about 1/5 gal each day to maintain pH in the recommended 7.2-7.8 range, though my range is more typically 7.4-7.8. I've read varying opinions that acid demand will be high on new plaster in the first month, or the first 3 months, or the first 6 months, or the first year. So maybe this is normal. But 1 gal/ 5 days of high concentration MA seems a lot more than the posts I've read of other high acid demand + SWG cases.
With this high acid demand, I am also adding Baking Soda once or twice a month to keep TA in range (60-80). I've read some of the info about carbon dioxide outgassing less at lower TA, but I don't see a difference in acid demand whether TA is on the 60 side of the range or the 80 side. Since the outgassing is also worse with lower pH, I'm debating whether to raise my pH target range to 7.6-7.8, but trying to keep that range may be impossible, and I assume it would hit 8.0 a few times per week.
This week I have shut off all the other features (waterfall, in-floor, spillover) that may add aeration to see if that has any significant effect on the pH rise. I'm not sure how much the relatively high surface area (stats in sig) of this pool contributes to CO2 outgassing; I do not have a cover, though I could make use of my homemade lily pads if that would help.
One last thing: I've had a few small outbreaks of mustard algae, but it seems like I meet the exit criteria for the SLAM (FC drop is 0.6ppm overnight, and CC is 0.2). Not sure this issue relates to the acid demand, but I want to fully disclose.
FC = 4.6 (drop to 4.0 in the morning)
CC = 0.2 (was 0.0 last week)
pH = 7.8 (added 1/5 gallon MA after this reading)
TA = 80
CYA = 80
CH = 380
Salt = 3300-3400 (per AquaPure readout; pool stores are getting 2700-2900)
SWG set at 30% for 10 hrs/day
Thanks for your help.
TA = 80
CYA = 80
CH = 380
