I'm brand new to the site...
I have been battling with small brown spots on my pebble tec finish pool for about 6-8 weeks now. My local pool store said it's most likely black algae and a "bear" to get rid of. I have been scrubbing them off with a wire brush and of course, the spots creep back every 2-3 weeks. The pool store suggested after I scrub them off to take a chlorine tab and scrub over the spot to help kill the root, which I did yesterday. I have also found, thru my snorkling, that there are a few deep crevices in the pebble tec and I can't scrub it all out. They then suggested to treat with a black algaecide - will this work? I've been reading a few threads and it seems everyone is SLAMing with liquid chlorine. We live in SW Florida and our temp is still 90, pool is 86 degrees and will remain open all year long. We are still using the pool every few days and all weekend long. I only have a simple 3-way liquid test kit and 4-way strips, don't know the best way to handle SLAMing, if necessary. As of yesterday:
FC - 3.0
PH - 7.4
ALK - 100
CYA - 60
I am 12,000 gallon pool with only 6 foot deep end. Also, pool is only 2 year old and never had this problem before.
We had hurricane Irma through my town, so my CYA is a bit lower than I like. I had added 2 lbs. shock to pool over past few days to sanitize and get chlorine back up again. I am also a salt water pool, so added 40 lbs. of salt (was low).
Thank you for any help you can provide!
FC - 3.0
PH - 7.4
ALK - 100
CYA - 60
