Good morning, new to the site but been lurking for a while learning about chemistry.
I purchased a new 175 gallon tub and plan to run bromine. I purchased and am testing with a Taylor K-2106 bromine drop kit.
I did my first fill this morning and my numbers are ...
Water temp 55 degrees
CH 320
TA 340
PH 7.2
I haven't started my bromine reserve\sanitizer yet.
I filled from a hose (well water and unsoftened) and used a pre-filter to filter out as many metals as possible.
I will re-test when water temp comes up a bit.
I read\re-read Nitros chemistry posts for tub but have a question.
My PH is 7.2 but TA is pretty high at 320. Since my PH is fairly acceptable do I bother trying to drop TA to ~100 range which would push my PH even lower? It seems like I might have to add lots of acid to drop TA to ~100. Do my current numbers seem to balanced given my PH stays at 7.2 or above?
Thank you for any advice you can provide.
macejh1
CH 320
TA 340
PH 7.2
macejh1
