I have a Hayward Super II that started leaking. When trying to remove the motor to replace the seal and o-rings, four of the six bolts must have been overtightened, because the inserts are just spinning. I can pry the case off about an inch before it hits the back wall, enough to see it in action. I'm not that handy (but learning), so any advice on how to remove the bolts from the inserts? Or on just pulling the inserts out entirely? If I get them out, can I just JB Weld them back into place? They're flush, so I can't get pliers on them, and pressing them with a screw driver wasn't enough force to hold the inserts in place while I torqued the bolts. Thanks for any help!
