So I just found your site and am trying to get everything lined out. I'm doing things in the wrong order. [emoji20] I did the borates and got it up to 50. Then got the correct test kit. My CYA was over 100 two days ago, so I drained 50% of my water, tested today after filling and here are my numbers.
FC 1.0
PH 7.6
TA 170
CH 300
CYA 100
BOR 30
Temp 87F
I couldn't believe my CYA was still so high so I went to the pool store to have them test to verify my numbers here is what they got.
FC 5.0
PH 7.8
TA 150
CH 250
CYA 98
So I'm draining again. Is there a better way good grief!? My signature is correct except 25k gal pool not 20-25.
20-25K gal, IG plaster, 1.0 HP Jandy Century single speed pump , 460 sqft Cartridge filter, Polaris 180 cleaner, attached spa, and waterfall. Taylor K-2005 test kit.
FC 1.0
PH 7.6
TA 170
CH 300
CYA 100
BOR 30
Temp 87F
FC 5.0
PH 7.8
TA 150
CH 250
CYA 98
