We have created a 16' circle and used a jumping jack machine to compact hard clay soil. There are some low spots in the pool, specifically on the lowest point.
Not sure where to go from here. I am reading all over not to fill the pits and valleys but to bring all the highest points around it to level with the lowest points.
I am going to use a Contempra 15' pool.
My question is this:
1. IF the area is level can I fill the low spots with crushed limestone?
2. IF I cannot get the site smooth (not sure if you are supposed to) can I use a thick 15' preformed pad?
3. IF the pad is acceptable do I still use sand? Would this be under or over that pad. I did order an optional pad for the bottom when I got the pool.
4. Can I use anything other masonry sand? What other sand is acceptable for under a pool?
Any help appreciated.
