I just replaced my old Hayward T-15 cell with the exact same model. (setting is correct in my diagnostics) When I first started running the pool after replacing it the chlorinator would shut down with the dreaded High salt/Amps message. This was no shocker, as I am pretty sure when most chlorinators start to fail and have low salt readings.... we all add salt. However, after replacing a lot of water - the salt level of my pool was tested today and was 3400... which should be in range, and not kick off the chlorinator. I noticed the other thread with this problem got highjacked by the "No cell power' fix... which does not fix the problem of high amps, but no amps. Has anyone had any success getting rid of the high amps (10.5) reading after installing a brand new cell. I know the maximum amps the T-15 can handle is 10 before it shuts off - I don't want to think I need to replace the PCB Board. When I kick the chlorinator on, the reading says 1900..... but I know that reading is not correct. I also get 1900 as my instant salt check number.
