Hey everyone, I am new to this website, and to the pool world in general. I've been reading up on the ABC's and trying to learn about all the pool knowledge lol. I have a Summer Waves 15x42 above ground pool, and I am trying to get it straight before Aug. 5th which will be my daughters 10th birthday party ( Growing way to fast! ) for the past few weeks money has been tight, and our pool at first was swamp green. I have gotten it to a light blue but its very cloudy now. Im still using the factory pump/paper filter that came with this pool, but I am buying a SWG system from a buddy of mine, go I am hoping to convert over this weekend. SO far based on the results of this kit (which im not sure how accurate the readings are)
Chlorine - after adding the 5 drops, it turned orange
PH lever -- based on the reading it looks to be around 7.8-7.8
Total Hardness -- think its low, pretty low
CYA -- this was pretty high, I would say around 120ppm
Total Alk. -- low, I stopped adding drops to the tube after 30, it had turned yellow, but this kit says to keep adding till it turns red I think.
can someone help guide in what I possibly need to do?
the SWG system im getting from my buddy, not sure the pump size etc. but the skimmer I have on the side of my pool now that the filters goes in, I wont be able to use his skimmer because its a square opening, so im assuming ill remove the pump that's in my skimmer now, and round this to the new pump ill have? lol
Thank you very much in advance
