Hey everybody, just a simple generalized question about the way you approach FC levels on a daily basis.
With my CYA level at 40, pool math recommends FC range between 3 and 7.
So i try to keep it at 5.
I test my water every morning before the sun hits the pool.
Get up, go out and test, and the FC is usually 4 ppm. So i add enough bleach to bring it up to 5, then walk away.
Next morning, test - usually a 4, add bleach to get to 5... rinse and repeat daily. I've been doing this for about 3 years since i started coming here to TroubleFreePools.
But this morning, i had a weird thought—and maybe this is a silly question, but is this the right approach, or is that daily dip to 4 ppm a problem?
If my target is 5 ppm, should i instead be adding enough bleach to bring the pool up to 6 ppm before the sun hits it, knowing that throughout the day it'll drop into my target level?
I guess my question is this:
Do you guys overshoot your target FC level knowing that it will drop back down into your target FC level, or do you just hit your target FC level in the morning, and just let nature do whatever it's gonna do the rest of the day?
