Starting a new personal thread so not to clutter the SWG run time one.
My salt generator (40K gallons) is plenty big enough for our pool (14500 gallons). I used the calculator and based on that, it is telling me I should only need to run it at 75% for 4.5hrs! Right now I am running it at 100% for 8.5hrs (pump on low) and still losing .5 - 1 ppm a day. I knew I would need to run the pump longer with the SWG but I didn't think I would need 9+ hours on 100%. The water is crystal clear, no issues since the day we filled the pool (this year). My PH keeps creeping up (TA is high) so I add MA about every 2 weeks to lower it back down. We had a ton of rain the last week and had to drain the pool a couple times so the salt level is a bit low but I will add more today. What could I be missing? I scrubbed all the pool yesterday and vacuumed. We get very little stuff in there. We probably have 3-5 people swimming a couple times every day so I know our load is higher than some. It gets full sun all day and I am in northern NJ.
Current Test Results
temp - 84
FC - 2
CC - .5
PH - 8.2 (will lower with MA today. It slowly goes up due to TA)
TA - 200 (slowly working to lower this)
CYA - 70
Salt - 2700
Edited to add: I am using test strips to check the salt levels. My SWG has never given me an error that the salt level is too low. I am not sure how accurate the strips are but my pool maint buddy says he likes them. The water deff tastes salty. Prior to the rain it was at 3000.
temp - 84
FC - 2
CC - .5
CYA - 70
Salt - 2700
