I Just hooked up a used Hayward s240 sand filter. put in new sand and turned on everything is okay except water is coming out from under the skirt. It does not come out when off ..that I can tell or when on waste, only on filter or recirculate. I can't really tell where it is coming from I am hoping it might be the little drain with the plug and I can just replace from outside (I really hope that is something possible). Does anyone have any ideas...also this is a side mount valve. I checked the ring no water seems to be coming from there or from the valve or pipes...I really think it is from underneath. I am a novice and hope that I don't have to take all the plumbing apart again or empty all the sand but it is losing a good bit of water. Thanks for any help. I am about ready to feel in the pool and call it quits.
