I'm fairly new to this and offering the best advice I can and referring to others advice too.As a note, here are a few observations:
1. Algae found - SLAM TIME
2. Buying "bleach" from Lowes or Home Depot, they store it outside. Here in Hou, the heat is 95% in the shade...if the product does not move quickly, OP is pouring water into his pool bc the h-acid is gone, case closed. It was also 6.25%
3. Does anyone know for sure the REAL CYA LEVEL ? I still feel this is very ambiguous and unclear.
4. What did the orig pool supply company dump in his water at fill-up ?? Any metals, borates, etc
STEPS:
1. get a definitive CYA test [for both SLAM and future stability of CL]
2. buy 8.25% from an air-regulated seller [ie, grocery store] or higher..
3. Once CYA is known, do SLAM and monitor
4. once stabilized, add quality bleach and take multiple tests daily till FC is in stable ranges for his location/external pool/water conditions...
STEPS:
Is there some other definitive CYA test other than the one offered in the K-2006? I'm not familiar with the TF-100 but it sounds the same.
Is it true that if you put 7ml of pool water in the container and add another 7ml of the cya test fluid and shake for 30 seconds you then squeeze it into the test vial fairly rapidly and look from the top to see if the black dot is obscured by the cloudy sample? If you fill all the way to the top and still see the dot is there another way to test for cya between 0-30 then?
Is it fair to say that a visible dot with the vial full is an idication of a cya level of 0-30 or technically 0-29?
