Hi, I have asked a few questions before and got excellent answers. I used the recommendations that were given and now I have a few more questions. I still have algae issues so I'm emptying 30% of the water to replace with new. I have a soft side oval above ground, 4393 gallons. Will I be able to refill just as easily as it is emptying (undid the hoses on the filter) and will the sides collapse? And what a waste of what looks like clear water.
I am also going to put 1 gallon of bleach in. Should I put the bleach into the water that is left in the pool, see how it does, then add the new water or put it in after the new water is in?
I see that it states that with an FC level lower than 8, (my test results are below)the pool is not safe for swimming. I went in yesterday to vacuum and skim. What is unsafe about it? Could I have details so I don't concern myself with getting a horrible disease? It also states that I should brush the sides of the pool. When would it be safe to go in and really give it a good cleaning (vacuuming & brushing)?
Hope you can help.
Stacey
FC - Chlorine/Bromine 2/4
pH - 8.4
TA - 120
TH - 0
CYA - 100 - This acronym gets me sometimes since it also means "cover your " heehee
Hope you can help.
Stacey
pH - 8.4
TA - 120
TH - 0
