Apologies from the start for the long post, but I just do no know what course of action would be best to take.
I have used baquacil for 2 years after a liner replacement. It is about 16x32 above ground, and is only opened seasonally. (Wisconsin, probably Late April to Late September or so). Cartridge filter.
I have never had what I consider an algae bloom, nor have I had mold/slime that seems to be described. My water is very clear. I do get brown dirt/debris on the bottom, kind of slippery in texture, and some green accumulation on the walls/stairs.
This year, I tried to be diligent with the baquacil, but due to an inability to get an actual baquacil number other than the strips which I don't trust, i over added, but still had a lot of the brownish/green debris on the floor and some on the walls. I added algacide and that seemed to help diminish the amount of brown some, but it is still there.
The pool store recommended vacuuming to waste (Which I have done at least 4 times) but this doesn't seem like a good long term solution. (And requires lots of water to accomplish)
I have added nothing to the pool for 3 weeks now, and the baquacil sanitizer level per the test at the pool store is still at 50, oxidizer at 0. My water is still very clear, but the brown is on the floor and some on the walls, which I am sure will require a vacuum to waste. (As a side note, when I vacuum through the cartridge, it almost immediately shoots the dirt back through the return and fouls the water up something fierce. I don't know if I am not supposed to ever vacuum through the filter, or if it is gummed up by the baquacil or overloaded?). Filter has been running 24 hours a day for over 3 weeks straight.
My consternation is that it is already mid July, I will be gone for 3 days next weekend, and I don't know if I should just deal with the dirt via vacuuming for now, or if I should convert, or if the brown debris/dirt would happen with either chemical, I should just stay with baquacil until I have issues, as I think its working?
As you can tell, I am an indecisive uninformed pool owner and I am looking to remedy that and get on a track where I can understand my pool and tend to it with less frustration/more confidence that I am not just pouring chemicals in and hoping for the best.
Last thing, I bought chlorine tablets a chlorninator, and non chlorine shock per an article about the conversion that I read. Now here I am seeing add bleach to bring chlorine up, is the bleach acting as liquid chlorine? Again, I may as well be starting from scratch here, in addition to deciding about the baquacil.
I attached pictures of the bottom of the pool and the stairs. Maybe someone can tell me what I am looking at and how troubling it is or isnt.
Thanks a lot in advance for any help you can give.
