Thread: FAS-DPD test
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    561
    FAS-DPD test
    I've been diluting my pool water with 50% chlorine free water so I could save my R-0871. Is that just as accurate as using straight pool water???
    Thanks
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Re: FAS-DPD test
    No, using dilution is less accurate. Depending on what you are doing, it might be good enough. It is good enough for determining shock level. It is not good enough for doing an overnight FC loss test.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    561
    Re: FAS-DPD test
    Thanks Jason. Guess I better quit doing that. I'm trying to tweak my SWG. Done with shocking
    Lynn
