Hello to all. New here,but have done a lot of reading and have asked a couple of questions on other threads. It was requested I start my own thread with my specific parameters. I live in Arizona and temps have been in the high 100's. 17000 gallon diving pool. I have a pool guy who comes once a week and chlorinates with two floating tablet holders. It was one until the CYA levels were high. Only owned this house with pool for about 7 months and this is my first pool. My plan is to stop service and take over the pool on my own. Here are my readings with a Taylor testing kit 2006. Taken at 1000 with water temp around 84 degrees.
FC 13.2
TC .4
TA 130
PH 7.2
CH 610
CYA 200 with diluted test. That is the x2 number
I put these numbers in the pool calculator for FC and CYA and it gave the following suggestions; Add 98 oz of 6% bleach to raise FC and drain 86% of water to lower CYA.
Not going to drain pool until after summer, but want to switch to liquid bleach.
So my easy questions are;
1 Do I pull the tablets and add the bleach and only use bleach to maintain FC?
2 of course continue to add fresh water as needed and hope CYA starts to drop a little at a time if no tablets are in the water?
3 Finish my final month with pool guy using chlorine and tell him I know longer want tablets? Or just get rid of him? ( he is aware my CYA levels are high and doubled tabs to keep chlorine up, but continues to increase CYA)
He also quoted 435.00 to drain pool and acid wash pool at end of season. Is this reasonable?
Sorry so long. Please add any comments you feel are necessary.
FC 13.2
TC .4
TA 130
PH 7.2
CH 610
