Hi, I'm new, to the forum but not to a pool. This is my 21st year of pool ownership and I'm just stumped.
We opened in April, live in PA, and I noticed it was really filtering slime through the filter. It was time so I had the multi port valve and sand changed as well as a new clorinator, on June 7th. I had gotten clean enough, but Cloudy, by adding cellulose fiber, on a suggestion of Leslie's pool. First off I never go onto Leslie pool but I had used Omni filter aid in the past and they no longer make it. So I thought ok.
It appears as though came right back in the pool.
So I vacuumed to waste a half dozen times to get the most of whatever it is out of the pool
I then had the valve head sand and chlorinator
made sure each three days the water was tested and spot on.
No luck.
emptied the pool of just above the returns three times.
Added clarifier ran Day and night and vacuumed to waste
no luck.
dumped more water to just above the returns
Got a slime bag they are out of stock so I got only one.
Three days of full running
Looks exactly the same,
vacuum to waste three more times
add more water
today. Looks exactly the same. It's a cloud that sits on the bottom.
Ive actually run the filter with the vac on flipped over so it would bottom feed since I have no main drain.
Does anyone have any other suggestions?
I did ask for new laterals but they said they were in great shape so we didn't replace them.
No Sand in pool so I assume they are right.
Thank you for any other suggestions I did order two diesel bags from a post long ago to make my own 1 micron bag since they are out of stock at slime-bag. I'd get all new water but I'm afraid I'd have to wipe the entire pool bottom first! And that's pretty drastic. I'm older so I sure don't want to do that.
No luck.
no luck.
add more water
