Hello Everyone, reading this forum has revolutionized my AGP life, thank you for all your advice and posts. Put up my 16x48 Intex Ultra-Frame last year just using the standard equipment. This year decided to partially hard-plumb, add a Hayward skimmer, and upgraded to a Sand filter. Got the pool up a few days ago and it's about 3/4 way full with water. I carefully followed the instructions on other posts and videos about installing the skimmer and I'm stuck...having extreme difficulty screwing it together, even outside of the pool the screws are extremely difficult to put in. Do I have to use a power drill? Do they need to be pre-drilled? Was just trying to hand tighten and I'm getting no where.
I split the butterfly gasket in half, I got in the pool and marked with a sharpie the holes for the screws inside the pool, used an awl to punch holes and got the screws through the liner. Lined up the faceplate, then gasket inside, aligned with gasket and skimmer on the outside and started to tighten the screws and I got nowhere! Would get 1 or 2 tightens of each screw and then met serious resistance. Screws going all sideways and un-aligned. I am using the flat head screws that came with the skimmer, but there are also 6 round-headed screws that came with the skimmer, do I use those somewhere? All the install videos and posts just say "then screw it together" and I can't figure out why I'm stuck at this step. It feels like the screws are a few MM too big for the skimmer??
Any advice appreciated
Thanks!
Sarah
Intex Ultra-Frame 16'x48" with SWG, Intex sand filter and partially installed Hayward standard mouth skimmer
Thanks!
Sarah
