I keep adding large amounts of Acid and want to try and get ahead to keep things more balanced and stop the large swings.
My guess is with the stupid spa/fountains, it's a large amount of aeration.
The problem & case history:
Moved into home in December.
With things warmed up now I'm fighting algae. With the pitting and blistering in the plaster I don't have near the time, nor the lung power, to brush all the black algae. [edit: it's in/under the chips and blisters]
I was able to make a good dent, especially along the water/tile line, when I drained the pool to dilute CYA. I had high CYA (100) so I drained 40-50% and got it blue again... only to go on a 2 week vacation. My dad helped out and dumped 2.5 gal 10% liq chlorine for me every couple of days, but I dont think he went often enough.. and apparently we got heavy rain which dropped my CYA to 30-35.
The numbers:
Using Taylor test kit, here's the results: (pool math app)
| DATE | notes |
| 5/23/2017 | water test |
| 5/22/2017 | add 16# 68% cal-hypo - brush walls |
| 5/22/2017 | water test |
| 5/20/2017 | start pool fill |
| 5/19/2017 | start pool drain |
| 5/18/2017 | water test |
| manage algae | minimal bleach added to keep at bay preventing bloom |
| 4/26/2017 | water test |
the Pool:
Drain before and after (4/26 - 5/19 era)
5/20
5/21
5/24
The numbers:
date | FC | pH | TA | CH | CYA | CSI | Notes |
6/15 | 0.0 | 8.0 | 150 | 300 | 35 | *Pool store test to validate CYA - They use Taylor reagents and appears Pentair CYA test tube | |
6/14 | 0 | 7.8 | 120 | 240 | 20 | .28 | |
5/27 | 3.2 | 8 | 140 | 260 | 51 | .55 | |
5/26 | 5.4 | ||||||
5/25 | 6.0 | 7.8 | 140 | 300 | 35 | .43 | |
5/24 | 8.6 | 8 | 140 | 250 | 30 | .56 | |
5/23 | 15.6 | 8.0 | 140 | 220 | 35 | .56 | |
5/22 | 5.6 | 8.0 | 130 | 210 | 68 | .46 | |
5/18 | 0.0 | 8.0 | 110 | 200 | 100 | .28 | |
4/26 | 2.4 | 8.0 | 100 | 270 | 100 | .29 | |
4/12 | 1.0 | 8.0 | 105 | 270 | 90 |
| DATE | notes |
the Pool:
5/20
5/21
5/24
