Should the padding material go under it or over the cove pcs?
Also, do most use a masonry sand under the gorilla pad?
20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
hayward sand filter(medium is echoglass)
Blue diamond robot cleaner
I'm using 1" of Screenings and a little over 1" of sand instead of 2 inches of sand. (I like the way the screenings pack down). The 1" of screening and 1" of Sand is sitting on top of my base which is appx 5-6" of well compacted screenings. (I have very rocky soil).
So it will be:
(from bottom to top)
Screenings
Masonry Sand
Gorilla Pad
Cove on top of Gorilla Pad.
(I'm also using wall foam)
Since the pad is sized for my pool, I'll be doing the cove on top of the pad (which is how I believe most people install it.
33'x15' x 52" Aqualeader
Gallons ? - (I use appx 13,500 to calculate "stuff")
33 x 15 x 4.3 x 5.9 = 12,558. or . . The Pool Calculator = 14,400
Hayward S-166T 100Lb Sand Filter - Hayward Power-Flo LX 1HP Pump
Intex S.W.G.
What is Screening?
I used 2-8 inches of stonedust (pulverized granite) compacted with a commercial plate compacter. I also have rocky soil and removed a lot of rocks (hence the inconsistent depth of base.
I mighht order a small amount of sand to spread out. The stonedust is ok but not as fine as mason sand. I just don't want to increase the depth any since I already put and partially filled on this liner I'm installing with.
I see pictures online of both above and below regarding the cove and pad. Asked 2 different pool stores and got 2 different answers too. Hence my posting the question. Sometimes it is better to ask real people with real pools.Sounds like it can be done both ways though.
I am not doing wall foam but would like to. All of the pool stores are telling me I would have to order it though so I never pursued it. Looks like it is just poly foam. Same that is used as underlayment for laminate flooring?
-Brian
