First, I sincerely apologize if this is covered elsewhere, but I couldn't find anything similar. If so, please point me to that thread!
Around my deep end, my blue (I believe Tahoe Blue) PebbleSheen is fading. It is not splotchy like any other issues/photos I've found, it's just faded and more brown-looking compared to the rest of the pool. It's nearly in a circle around the deep end drain. In the attached pictures, there is a defined curved 'line' around the train, where the coloring obviously changes.
The pool is 4 years old now. I feel like this had been here a while, but it seems like it may be getting worse. I discovered this website ~3 years ago and have been using Chlorox Bleach ever since. It's obviously disconcerting that I may be 'bleaching' my pool, but I assume everyone else would be having that problem if it were possible, so that's probably not it. I feel like if I told my pool company that though, they'd blame me for using Bleach!
I did test my water yesterday, and here were the results.
CYA ~ 80 (I know this is high...I feel like it was high when I first got the pool though? Does that happen because of any construction/plaster leeching into the water the first time?)
Alkalinity is ~70. I know I need to add some Baking Soda to bring this up. FYI, when I first tested it, my Alkalinity was ~200. I had to use the method I found on here, adding acid and running my fountain, for a few days before I could it down to ~120 3 years ago.
FC: 6
CC: 0
So I guess I have a few questions:
1) Anyone know what is causing this fading?
2) How to prevent this getting worse?
3) How to fix it? If it's a permanent 'fade', is it even possible to drain the pool, acid wash, and reapply the blue coloring? Or do you have to rip out the pebbleTec and start from scratch (expensive!!! ouch).
Thanks very much for any input! I have had less issues than all my friends by using the methods on this site, so you all are a blessing! I just now can't figure out this 'fading' issue!
Jason
FC: 6
CC: 0
Jason
