I'm learning that pool products aren't always the best to use on a small swim spa. I've read where this forum recommends Startup Tec for metals. I called the manufacturer of Startup Tec today and asked the tech person if this product is ok for small swim spa with heater. She recommended Beautec instead. Said it lasts longer and isn't as expensive as Startup. She said its ph/Alk neutral and doesn't affect chlorine. I used Proteam metal magic on initial fill and had no problems. We really don't have an iron/staining issue from our water but I've had no problem with metal magic and want to ensure no problem with this drain/refill. Any advice on Beautec vs. Startup tec?
( Beautec is same as "the ultimate scale and stain controller" by Leslie.)
