I've read several postings on here including the Pool Water Chemistry one by Chem Geek. That has gotten me pretty far along in understanding that Na+ and Cl- are separate ions when dissolved, which by itself dispels lots of mythology. And I'm on-board with aeration being the primary cause of pH rise. But I could use some clarification to firm up a couple of things in my mind.
1. Does hydroxide at the negative plate NOT form sodium hydroxide, or is it just completely irrelevant whether or not there are sodium ions involved, since you still have hydroxide that gets at least partially negated by the products at the other electrode (see #2)?
2. Chem Geek's post shows two of the products of the positive plate as H+ and Cl- instead of showing HCl. Is that because the hydrogen ion and chloride ion are the same as what you'd get by adding HCl to water?
I just want to have all this straight in my brain to make sure that I don't pass along myths. I give mini pool chemistry presentations on things like chloramines, CYA, etc. and you can almost see people's brains twisting because they have bought into myths for 20 years.
