I like the idea of using polyquat. It does cost $25 a bottle, but you will use it. A weekly dose is required. It is good to make allowances for people who skip days, read test results incorrectly, follow directions wrong, etc. Using polyquat provides a lot of insurance against these kinds of problems.
For PH adjustments, there is no need to know the TA. You just give them a standard "raise the PH" dose and a standard "lower the PH" dose and then have them repeat the dose until the PH is in range.
For fractional oz you use teaspoons, six teaspoons in an oz.
I am imagining a web based calculator. You tell it what size pool you have and it gives you a page you can print out with all of the instructions and the specific doses of everything.
I am imagining that the target audience is pools with pumps and filters that get completely emptied each year. Without a pump/filter the instructions should be simpler still, and that isn't really what I am interested in. The pool has to be small enough that they are willing to empty and refill if something goes serious wrong. The goal should be to go a whole season, but major mistakes/problems should be allowed to require a complete drain/refill. In practice this probably means 1,000 to 5,000 gallons, but both ends allow for some variation depending on the owners attitudes.
I figure the test kit can be OTO TC, PH, and TA. That would be something like a Taylor K-1003. Another way to go would be a DPD test kit, like the Taylor K-1004. It doesn't cost much more and gives you much better chlorine test results. Leslie's has a K-1004 equivalent, but I don't think that WalMart does. The remaining two options are to go low end, the K-1000 OTO and PH, clones of which are available everywhere. Or to go more complex and not necessarily better, the WalMart 6 way kit. Keep in mind that I am not pushing Taylor, TFTestKits can do a similar kit if they want to, and we might find other brands that are alright, like WalMart. I am just using Taylor to layout the options. Just at the moment, I like the Taylor K-1004.
