First time pool owner with newly built IG pool. Started vacuuming for the first time Saturday. Bottom of pool had lots of dirt in it from the somewhat sloppy backfilling job and from a very heavy thunderstorm on thursday night that splashed a LOT of dirt into the pool. (That's a whole nuther issue....controlling the dirt while waiting for deck to be installed...UGH!) All new equipment...vac, hose, skimmer plate, etc. Had trouble at first priming the hose first couple tries using the return so I found fishing the hose down into the water easier. Once I figured out how to partially close off the floor drains the vacuum worked well. However, it lost all suction after 15-20 minutes each time I started vacuuming and the pressure at the filter dropped to near zero. So I would shut the pump off, clean the pump basket, re-prime it, set filter to backwash and re-start it. Once waste water was clear I rinsed, then set it back to filter and would try vacuuming again. Hugh PITA doing this but I managed after 4-5 times to get most of dirt off floor of pool but I would still like to clean it up a little more and understand why this may be happening. This isn't normal, correct? I know not to lift vacuum head out of water. The vacuum is one of the triangle shaped clear blue plastic ones. I looked thoroughly at the hose and do not see any cracks or holes, etc. The skimmer seems to be functioning properly when not vacuuming. I hold the skimmer plate under water and then transfer over deck down into skimmer so I imagine a small amount of air enters the hose when that happens, but like I said the vacuum seems to function fine but not for longer than 15 min. PLEASE HELP!
