Thread: Will I ever need to use my MPS shock with the bbb process?
    May 2017
    Central FL
    27
    New to bbb process. The place I bought the spa from recommended 2-3 tablespoons of MPS shock after each use. Do you recommend this with bbb process? Will I ever need to use MPS shock on this process? If so, when?
    Master Spa Trainer 15 Eco Pure System w/mineral filter. Fiberglass. 15'x8'. 4' deep. 1,895 gal. 2 pumps. 55 jets.4 swim jets. 2 waterfalls. Ozone system. Partially sunken (2' above ground). Insulated, thick cover. 8.25% BBB process. 95 degrees. HTH 6-way test. Central FL . Well water.
    JoyfulNoise's Avatar
    May 2015
    14,210
    Re: Will I ever need to use my MPS shock with the bbb process?
    Quote Originally Posted by Villagesilvergirl View Post
    If you had a high bather load, it could help to reduce the recovery time of the spa. MPS is just another oxidizer (note: NOT a sanitizer) and it can work in conjunction with chlorine to clean up after a heavily used spa. Typically speaking, a well maintained chlorine hot tub will have little use for MPS.
    Downsides to using MPS is that it interferes with the FAS-DPD chlorine test and it adds sulfates to the water which can be hard on the cheaper forms of spa heaters (those made of Incoloy metal).
    Matt
    May 2017
    Central FL
    27
    Thanks so much for the response. I'm learning so much!
