I just emptied my pool four years after resurfacing.
When we had the resurfacing done, I treated with several pounds of bicarb. Is this necessary with the refill or was that just needed to help cure the new surface?
My pool man is suggesting that I not use Cyanuric Acid when I adjust the chemicals, just chlorine and muriatic acid until I have the right balance. Does that sound ok?
When I filled the pool after the resurface, I had trouble balancing and keeping ph at the recommended 7.4-7.6. What's the best way proceed? Is there a proper sequence? Amounts of acid, chlorine?
