Thread: Motor upgrade for Pentair Challenger
    Jan 2017
    Atlanta GA
    6
    I have a pentair challenger with single speed motor that needs replacement. Want to go to 2 speed to save operating $.
    Can I just change the motor or do need new pump too?
    Have an Aqualogic PA-8 with available relays. How much time do you set up for each speed? Is there a setting for 2spees motors?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Motor upgrade for Pentair Challenger
    Give the folks at Inyo Pools a call, they can help you out with that.
    Jan 2017
    Atlanta GA
    6
    Talked to INYO pools. Great service. Ordered the variable speed ECM16SQU and seal kit. Should bolt right on.
