Thread: What is the device in the photo?
    May 2017
    Little Rock, AR
    1
    I'm a relatively new pool owner, and I'm fighting a leak somewhere in the pool. I had a local pool company use a device to scan the pool for leaks, and the device detected nothing. I changed the gaskets on the returns and the skimmer boxes, and the problem has worsened slightly. I want to add some silicone where appropriate. To do so, I'd like to vacate the water around the particular return as I service it. I've attached a photo of a device that I viewed in an online video. What is the device called?
    Jan 2012
    'burbs of Augusta, Georgia
    8,586
    Re: What is the device in the photo?
    Maybe a dam of some sort for pools?
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Aug 2016
    Pittsburgh PA
    345
    Pretty cool idea. Would've been handy on my previous above-ground when I made repairs to the return.
    It's like a mini-dry dock for pool repairs!
    18'x36' vinyl - 24k gal - Intelliflo 3hp VSP - Pentair C&C 420 cartridge filter - IC40 Salt - EasyTouch 8 - ScreenLogic - Raypak 406btu NG heater - Intellibrite 5G ligths - 4 deck jets - sheer descent - X-Stream Slide 2 - TF100 kit - opened spring 2017
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    Cofferdam, size scaled to fit your needs. neat idea..
    You may be able to take any large round bowl that you can cut in half and put some weather-stripping between the bowl and the pool wall. pump/ suck the water out and the pressure should keep it firmly against the wall.
