Page 1 of 4 1234 LastLast
Results 1 to 20 of 73
Thread: First SLAM
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Lightbulb First SLAM
    I'm a new member and pool owner who bought a house with a green pool. My K-2006 arrived and I will be testing my water levels tonight. I have been scooping out leaves and brushed the pool a bit when i took the winter cover off Friday.
    My pool measures 16 x 38 and has a shallow end of about 3' and a deep end of about 6', which is about 20500 gallons according to Pool Math.
    I need these levels:
    FC
    CC (added)
    Ph
    TA
    CH
    CYA
    All of my other info is in my signature. Is there anything else I missed?
    Thanks in advanced
    Current & First Pool: In-Ground w/Liner 18'x37' 20,500 gallons
    1 HP Hayward Super Pump
    Hayward Superflex Filter EC75A
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: First SLAM
    The bad:
    Nov 2014
    United Kingdom
    226
    Re: First SLAM
    You will want to know the combined chlorine
    10,000 gallons inground Leisure fibreglass pool, Hayward powerline pump, Quality120 glass media filter, 27kw output air source heat pump and thermal cover.
    Retractable cover with Polycarbonate roof and glass side for all year round use. K-2006C test kit and Speed stir
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: First SLAM
    added it.
    thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,301
    Re: First SLAM
    Great photo!
    Ideally, you'll take a picture looking down at the steps every day and post it it, so we can see the color and clarity improve every day and see the steps appear out of the murkiness one at a time. Then we point to this thread when the next green pool story comes along.
    Jan 2010
    Spring Texas
    48
    Re: First SLAM
    Good grief that's a swamp. I had the same a few years ago and got through it following what these guys on TFP told me to do. I have cartridge filters and made the mistake of vacuuming through the filter after a big algae kill. I was forced to clean my filters 3 times for each vacuuming job and it was a horrible waste of time. I should have dumped it to waste and replaced the water. You will learn a few new tricks I am sure.
    Good luck
    20000 gal in ground Pentair Screenlogic 2 ez-touch 4
    Teledyne heater Compupool 40k Salt generator
    Pentair VS pump Hayward 4025 Cartridge Filter
    12 person Spa The Pool Cleaner robot
    lot of bushes and trees close to the pool
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: First SLAM
    I think the previous owner replaced the liner and just filled it back up with hose water, winterized the plumbing and let a bunch of tasty treats fall in before putting the winter cover on. I can scoop stuff off of the bottom with the net... I will be scooping and vacuuming to waste for a while I think...
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: First SLAM
    Bad news. I've been scooping delicious snacks off of the bottom of the pool with the basket for 30 min now.... I dont think I want to vacuum through the Pentair DE. What can I do? Can I get someone out here to vacuum the pool with their own pump? I really dislike the previous owner of this pool right now...
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: First SLAM
    Is starting over and draining a vinyl in ground pool a bit extreme?
    Jan 2017
    Monterrey, NL, Mexico
    492
    Re: First SLAM
    Its not recommended to do a full drain for a vinyl IGP, it will wrinkle and shift. You can drain most of it by leaving at least a foot of water on the shallow end. That would make it easier to clean and scoop stuff out. You can also rent a pump from homedepot or lowes.
    Felipe
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: First SLAM
    I think I got most of it out. I'm going to take my initial levels this evening. Looking forward to SLAMING this pool with TFP
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: First SLAM
    First results. I'm fairly confident, it was an easy process.
    TA 30 ppm
    CH 70 ppm
    pH 7.0 maybe less? Very light yellow looking
    CYA less than 30 ppm (went to very top of the tube could still see dot)
    FC ~ .4ppm. 2 drops at 25ml
    CC ~ .6 ppm 3 drops at 25ml
    What's first. I know there is still some junk in the pool but I've scooped out a lot but I can't see the bottom either.
    Richard320's Avatar
    Jan 2010
    20,301
    Re: First SLAM
    Quote Originally Posted by Mkleisch View Post
    TA 30 ppm
    CH 70 ppm
    Question: Did the CYA mixture get cloudy at all, or did it look unchanged when you mixed things? If it clouded up some, so that the dot is a little hazy, figure you have 10 or 15 CYA now. If nothing happened, the previous owners either never added any or it broke down.
    Your pH adjustment is going to be finicky with such low TA. I suggest starting by raising TA to about 60, give it a little time to mix, maybe give things a brush to help speed it up and go have a beer. Then recheck pH and TA. The pH might have risen a little and you're good, but if it hasn't, you'll want a good TA number to calculate the dose to raise pH to 7.2. As a point of interest... if the previous owners left any pool chemicals behind, let us know. You might be able to use some of them.
    When pH is good, dose the pool to 10 FC, since there's no CYA. Then fumble with the sock and enough CYA granules to get to 30 ppm, and set that in the skimmer, provided it doesn't block the flow. And after that it's just test and bleach and brush and vacuum and repeat.
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    First SLAM
    CYA never looked cloudy to me.
    So Pool Calc says 144 oz baking soda by weight. I'll do that and check pH and TA again.
    I'm kinda baffled what the previous owner did. There was a ton of stuff in the bottom of the pool and a winter cover. It was even winterized with antifreeze.
    I will post an inventory of left over chemicals.
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: First SLAM
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    First SLAM
    Chemicals on hand.
    Malibu pH stabilizer
    Malibu Chlorine Stabilizer
    Malibu pH increaser
    Muratic acid
    In the swim alkalinity Increaser
    Pool Pride pH reducer
    4 gallons 10% chlorine
    3 gallons 12.5% chlorine
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    First SLAM
    I'll check the TA in a few. I just added the baking soda.
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: First SLAM
    TA of 60 achieved.
    pH still looks like 7.0 to me
    Richard320's Avatar
    Jan 2010
    20,301
    Re: First SLAM
    TA of 60 achieved.
    Use either of the pH increasers to get to 7.2. Use the washing soda calculation in poolmath because that's what it is, just packaged fancier. Then you can use that liquid shock to get the FC up. I doubt if any of it is full strength anymore. Shoot for 10 FC, but don't be surprised if ten minutes after adding if its zero again due to weak bleach and green pool. When you can get a reading of 5 or better 10 minutes after adding, then you can add some CYA and commence a standard SLAM. You needn't wait for the CYA to dissolve to SLAM.
  20. Back To Top    #20
    Mkleisch's Avatar
    Mar 2017
    Naperville IL
    78
    Re: First SLAM
    I assume starting the slam without being able to monitor it every few hours is a waste of time? I will have to start raising the FC Thursday afternoon and SLAM over the holiday weekend.
