Thread: TA is low
    Apr 2017
    new caney tx
    16
    TA is low
    I have been using this method to take care of my pool for a couple of months kind of getting the hang of it. Still lots of questions though.
    Trying to maintain PH at 7.2 but I'm adding muriatic acid every couple of days.
    My numbers are
    ph 7.2
    CH 300
    FC 15
    CC .05
    CYA 80
    TA 70
    Water is crystal clear. I'm worried my TA is to low. Should I add something to raise it or should I just keep monitoring it.
    Thank you
    24k gallon, 16 x 37 IG , Gunite, Pentair cartridge 420, Whisper Flo Pump 2hp type CX model 011774 has 2, Polaris 280, built 09, TF-100 kit, Also has a wood burning heater.
    Re: TA is low
    I would recommend that you keep pH at 7.8.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: TA is low
    +1 to pH at 7.8 and 70 is fine for TA. Here are the recommended levels, Pool School - Recommended Levels
    Nov 2016
    Helena, AL
    227
    Re: TA is low
    Quote Originally Posted by pooldv View Post
    Why 7.8? That's the top end of the recommendation for range.
    30k IG vinyl w steps , Pentair SuperFlo 342001 pump, StaRite Cristal-Flo sand filter T-240-BP1
    Hayward Goldline AQR15 SWG, Dolphin Premium (aka S300i) Robot
    Borates & TF100 test kit
    200 gal hot tub (that I completely rebuilt)
    Re: TA is low
    7.8 creates less carbon dioxide. Carbon dioxide causes ph rise.
    Higher ph means more ph stability and less acid. It also helps maintain good CSI.
    Support the site
    30,961
    Re: TA is low
    TA is fine at 70.
    If pH will rise on it's own, then let it slide on up to 7.8. If it does not rise, I would leave it alone
