If the spigot is in the pipe sticking up and leading off to the filter, yes, with some caveats.
But you have to have a way to only drain from the main drain at the bottom of the pool. If you can't shut off the skimmer, it'll only work until the water goes down to the skimmer level, then you'll just suck air. It's also going to be slow, since a garden hose will only flow about 1/10 as much water as a 1½" discharge hose hooked to a rental pump. The rest of the water you're pulling in will go through the filter and shoot back into the pool. It'll cost a small fortune to run that big pool pump 24 hours a day for 3 or 4 days to empty it. A high capacity pump from a rental place (rumor has it home depot rents them, too. Worth a call) will empty it in a couple hours.
