Results 1 to 14 of 14
Thread: 1963 20x40 inground renovation ????
    May 2017
    Parma ohio
    9
    Hello to everyone. I have a 20x40 inground pool with steel walls and a cement floor. It's 3ft to a 8ft hopper bottom with a safety ledge. It was/will be again a DE pool. My grandparents but this pool in and I've bought the house and time has come to restore it. The pool hasn't been open in 20+ years. All the pipes were filled with rv antifreeze and still are. Ok my main question is what do I do with the coping situation. It currently has an overlap liner. Wrapped over a 2x8 which is bolted to the top of the wall (its bent 90deg over the concrete decking) then a white vinyl ribbed coping over that. The coping is above the cement decking. Is it possible to replace this or do I have to go with a track/bead system. Then figure out a coping. Any help is greatly appreciated thank you. Eric.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,987
    Re: 1963 20x40 inground renovation ????
    Hi there! What a neat back story on the house/pool! 20+ years of sitting there? Is the pool covered?
    With the coping I think a picture or 10 will be most helpful so we can see what you are dealing with!
    This will be a fun one to work on and figure out!
    Kim
    May 2017
    Parma ohio
    9
    Hi. Yes the pool has been covered with the mesh/screen style winter cover the whole time.
    Jul 2012
    Tallahassee, FL
    33,987
    So it is a green swamp. Is it a eco system with critters and plants?
    Can't wait to see how they did this pool!
    Kim
    May 2017
    Parma ohio
    9
    May 2017
    Parma ohio
    9
    http://
    http://
    http://<a href="http://s997.photobuc...&#91;/IMG]</a>
    http://
    Ok. Phew I got the pics in. Now I know it's rusted bad. I'm not afraid of that. I'll make that look new again where the top sill is missing. But what do you call this style of liner and coping besides old and obsolete. Is it possible to put it back this way. I mean I worked since '76 when this liner was put in.
    Jul 2012
    Tallahassee, FL
    33,987
    This is SO outside my realm of experience it is not even funny but............we can piece it together to see what might or might now work.
    Lets go part by part:
    -walls are steel-are they rusted at all?
    -the rusted pieces laying on the coping-how were they attached to the walls before?
    -The wood was attached to the rusted pieces?
    -The liner was "wrapped" around the board and attached how?
    What is under the cement/coping?
    How thick is the cement/coping?
    Kim
    May 2017
    Parma ohio
    9
    Yes the walls are steel they are rusty.
    The rusted pieces laying on the concrete are part of the wall that came up and bent 90deg over the concrete decking. About 5.5 in.
    The wood was bolted down down to the metal flange the rusted pieces the second picture shows what the metal should look like. I unbolted the wood
    the liner yes goes up and over the board and is nailed in place with roofing nails
    the cement deck deck is fine al the way around the pool. In the last picture that white strip fits over the liner covered board and is made of vinyl. The sides are also nailed to the board. Double lipped to cover the nails.
    I cannot find any info anywhere on this setup. It's to simple and cheap I guess. I know the coping is above the deck for a potential trip hazard but I grew up using this pool and it's never caused an issue.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Man, this will be quite the project!
    Ill be watching, and wishing I could add some solid advice. Out of my realm of knowledge too.
    Essential Links:
    Jul 2012
    Tallahassee, FL
    33,987
    Our deck is under our coping rail so could be a tripping hazard as well but I like how it looks so........that is how hubby did it.
    So you need something for the liner to "hook" to. I do like the idea of adding a liner hanger and using a beaded liner. Here is a link to one:
    Bead Receiver Kit (48 Section) - NL109 - INYOPools.com
    Once you get that figured out you will need to do something to keep water from getting behind the walls. I am thinking flexible caulk or such. Do some searching and see what you can find.
    THEN you can work on a new coping to take the place of the wood.....many ideas out there. Bricks? small stepping stones? Once you pick what you want we can come up with a way to attach them!
    Kim
    May 2017
    Parma ohio
    9
    Has anyone seen this liner set up before ??
    May 2017
    Parma ohio
    9
    Bump
    May 2017
    Parma ohio
    9
    Jul 2012
    Tallahassee, FL
    33,987
    What a lot of work you have done so far! Is that the creature from the black lagoon down there?? LOL
    Kim
