Thread: Pump taking a long time to begin circulating water
    Apr 2014
    Gilbert, AZ
    3
    Recently I noticed my pump taking a lot longer to begin actually circulating the water. It starts at high speed like normal but it seems to have trouble getting primed. Sometimes it doesn't start circulating water at all and I have to shut it down and wait for a while to start it up again. One more note: this happens most often after I clean the pump's strainer basket. Any wisdom is appreciated.
    Built April 2013, 11k gal, IG Pebble, Hayward EcoStar SP3400SVP pump, Hayward SwimClear cartridge filter (Model C4030 425 sq ft) 150 GPM, Paramount ClearO3 Ozone purifier,
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,305
    Re: Pump taking a long time to begin circulating water
    S,
    Welcome to TFP.. A Great resource for all your pump priming issues..
    Most all priming issue are related to the O-Ring under the pump lid.
    If this seal is not perfect, air will leak in keeping the pump from priming.
    I suggest you inspect the O-ring for any damage. If none, coat it with pool-lube and try it again.
    Thanks for posting,
    Apr 2014
    Gilbert, AZ
    3
    Thanks Jim. I'll give it a try.
