I am new to the website. I start to own a swimming pool from this year. After doing googling work, I have found the useful forum, from which I have learned a lot.
Here is the story about my pool. All the measurements haven made using Taylor 2006 kit.
On 5/5/2017, I opened my pool.Below was the parameter I got:
FC 0
CC 0
CYA 0
pH 7.8
TA 130 ppm
The low CYA make me believe that the CYA was decomposed into amine during the last winter because I saw previous owner had been used pucker to maintain the pool.
For the slamming of my pool, I first turn off the inline chlorinator. Every day I had to keep my closed because the CyA level zero so that I can keep a high concentration of FC to slam my pool.After I used almost 24 gallons of 10-12.5 liquid chlorine. Below are the measurements that I got on 5/13/2017.
FC: 4.5
CC: >6.5
CYA: 0
pH 7.3
TA: 150 ppm
I believe that I still need to add much more liquid chlorine to the pool to burn the CC. I would like to know how I can use 10% liquid chlorine to efficiently burn the CC. My pool is vinyl liner and has 20000 gallon water. Here are my questions:
1. What is the maximum gallons of liquid chlorine (10% ) that can be added every time to burn the CC without damaging the vinyl line and other equipment?
2. After adding the liquid chlorine, after how many minutes should I measure the CC after adding the liquid chlorine?
3. How frequently can I add the same amount the liquid chlorine to the pool?
4. I did not add CYA, therefore all the Slamming has to done at the dusk or when the pool is covered. I am going to use pucker to elevate the CYA levels after the pool slamming is finished. Does the strategy works?
5. In the coming winter, what procedures I should follow to prevent CYA from decomposition into amine?
Thanks for your suggestion.
FC 0
CC 0
CYA 0
pH 7.8
TA 130 ppm
FC: 4.5
CC: >6.5
CYA: 0
pH 7.3
TA: 150 ppm
